[FOSS-GPS] Using RTKLib with Novatel OEM device as base
davidkelley davidkelley at iTSware.net
Wed Sep 3 09:11:52 PDT 2014
I am sorry for not reading your thread better, will do so next.  When I have looked at the source code for the RTKLIB consumption of other devices (hemisphere and ublox) it simply ignores messages it does not care to cope with - so there is no need to filter out unwanted messages in the stream.  And when you need to add a message detail, it is fairly easy to do so. But I presume you do not want to code there. I am not clearly seeing your problem. Did you expect the small table you posted to be a valid RTCM defined msg then, or to be in the Novatel format? If this was valid RTCM, then 3 byes in should be the message type, 12 bits long, and I can not find that pattern.  How are you doing your framing logic?
And, to harken back to basics a bit as per Antons prior comment,  did you every mange to use the OEMV-3 as a rover in "single mode?
Regards, David Kelley, 626-485-7528 sent from a touch screen, please excuse my spelling.
-------- Original message --------
Date:09/03/2014  8:35 AM  (GMT-08:00)
To: foss-gps at lists.osgeo.org
Subject: Re: [FOSS-GPS] Using RTKLib with Novatel OEM device as base
David,
I'm actually not using the RTCM output, but rather the proprietary OEMV
output.  The receiver does output RTCM data, but it appears to still be
encapsulated in the OEMV format when doing so. (the specification shows the
same header info as the other messages)
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Using-RTKLib-with-Novatel-OEM-device-as-base-tp7572967p7572986.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140903/f0882715/attachment.html>
More information about the FOSS-GPS mailing list
