[FOSS-GPS] R: Re: Postprocess UBX raw data
frsisani at tin.it
frsisani at tin.it
Thu Sep 18 00:55:08 PDT 2014
Hy Yanqing
probably for you is it easily but I'm not able to post process the data that I have collectedIs it possible to send you the raw data and observation from base station to check ?
Thx in advance
Francesco
----Messaggio originale----
Da: fishloveocean at gmail.com
Data: 13-set-2014 12.53
A: "Open Source GPS-related discussion and support"<foss-gps at lists.osgeo.org>
Ogg: Re: [FOSS-GPS] Postprocess UBX raw data
There is a step-by-step tutorial in the document provided by rtklib. You can use rtkpost easily by following these steps.
Yanqing
2014-09-13 8:53 GMT+02:00 checco68 <frsisani at tin.it>:
I My name is Francesco and I'm new
I have purchased a lea6t module (raw data output available) because in my
region there is a gnss free network from University so mi idea is to collect
the raw data (kinematic mode ) and then post process the data with rinex
files from base station but I'm not able to set up correctly rtkpost to
process the data
Can you help me please ?
Thx
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Postprocess-UBX-raw-data-tp7572995.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140918/2a0b9137/attachment.html>
More information about the FOSS-GPS
