[FOSS-GPS] RTKLIB sample tests
jeremy.bouathong
bouathbouath at gmail.com
Tue Sep 23 00:06:58 PDT 2014
Hello,
my name is Jeremy Bouathong. I'm working on RTKLIB for a few weeks, and I
will receive EVK 6T-0 (evaluation kits for LEA 6T-0) soon (1 week or 2) . So
for the time being i'm trying to manipulate the samples. I can make them
works perfectly with the APIs. So now i'm into the source code. I'm trying
to get the raw datas from the samples but it doesn't works. I don't know if
i can read the files actually. Here is what i've done
raw_t raw={0};
FILE *fp = fopen("FILE_PATH\oemv_20090515c.gps", "r");
char mystring [SIZE];
if (fgets (mystring, SIZE, fp) != NULL)
cout << "Fichier non vide" << endl; // with this i know that my file
isn't empty
else
cout << "Fichier vide" << endl;
cout << input_oem4f(&raw,fp) << endl;
it always return me -2. I checked with RTKCONV and the file has obs and nav
datas. So i should return 1 & 2. I tried with i for loop i only get -2...
PS: i have some basics in programing but i'm not an expert.
Regards,
BOUATHONG Jeremy
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-sample-tests-tp7573016.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
