[FOSS-GPS] R: Re: R: post-processing in RTKLib
David Kelley
DavidKelley at iTSware.net
Sat Apr 25 09:46:28 PDT 2015
Francesco:
Your connection path seems to be incomplete. What is the mount point
you expect to use? See the line "inpstr2-path" in you config file.
[Said more plainly, what/where is the base station you seek to connect to?]
The stock reply from an NTRIP caster when you send it an incomplete or
incorrect specification (in your case no mount point) is to return the
current caster table (the table of mount point) and disconnect you. If
you use the 'map' button with the NTRIP browser you can see the North
Eastern region of Italy your caster supports, pick one of these (typical
the closest) to use.
I presume you have valid credentials on that caster as well. I just
tried what is in your file (please beware that is a security leak to
others) with the mountPt "Padova3" and it did not work for me. If you
do not have access rights to a closed, the caster will it reply with
'401 unauthorized' and the RTKLIB tool will mindlessly retry every 10
seconds or so forever.
Good luck, David Kelley
On 4/25/2015 8:36 AM, frsisani at tin.it wrote:
> Hy all
> attahced the config file My task is to obtain the fix using Ublox
> lea6t and correction provided by Ntrip (Base station)
> I receive always the timeout message so it seems no message from base
> station in received from rtklib
> Please help me
> Thanks in advance
> Francesco
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150425/51e7dd59/attachment.html>
More information about the FOSS-GPS
