[FOSS-GPS] RTKLIB RTKCONV RTKPOST
    dan marcotte
    jdanielmarcotte at yahoo.ca
    Mon Aug  3 08:48:16 PDT 2015
Hello MacSam
the Neo 6P are capable of cm accuracy assuming that the base is less than
10km
and your have raisonnable quality antennas...
you need:
1. to set up the positionning mode to either cinematic or static
2. enter the precise position of the base station including height
btw your device is L1 only
sbs is facultatif
and of course, it will not work if your base station is a bad reception
situation
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-RTKCONV-RTKPOST-tp7573249p7573263.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
