[FOSS-GPS] RTKLIB RTKCONV RTKPOST
macSam mike.mcloughlin at rockmate.com
Tue Aug 4 03:38:55 PDT 2015
Thanks Dan,
Where do I add the base station lat and long?
Regards
Macsam
> On 3 Aug 2015, at 16:48, dan marcotte [via Open Source GPS-related discussion and support] <ml-node+s1099874n7573263h27 at n2.nabble.com> wrote:
> Hello MacSam
> the Neo 6P are capable of cm accuracy assuming that the base is less than 10km
> and your have raisonnable quality antennas...
> you need:
> 1. to set up the positionning mode to either cinematic or static
> 2. enter the precise position of the base station including height
> btw your device is L1 only
> sbs is facultatif
> and of course, it will not work if your base station is a bad reception situation
> If you reply to this email, your message will be added to the discussion below:
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-RTKCONV-RTKPOST-tp7573249p7573263.html
> To unsubscribe from RTKLIB RTKCONV RTKPOST, click here.
> NAML
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-RTKCONV-RTKPOST-tp7573249p7573264.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150804/99612769/attachment.html>
More information about the FOSS-GPS mailing list
