[FOSS-GPS] RTKLIB RTKCONV RTKPOST
macSam
mike.mcloughlin at rockmate.com
Wed Aug 12 11:51:13 PDT 2015
Hi Dan,
Back in the office.
The NEO 6P is NL-6002U unit which comes with an antenna attached.
I have processed the base station data separately:
% program : RTKPOST ver.2.4.2
% inp file : E: \data\results\150729b.obs
% inp file : E:\data\results\150729b.nav
% inp file : E:\ data\results\150729b.sbs
% obs start : 2015/07/29 17:14:41.0 GPST (week1855 321281.0s)
% obs end : 2015/07/29 17:23:52.0 GPST (week1855 321832.0s)
% pos mode : ppp-static
% solution : forward
% elev mask : 15.0 deg
% dynamics : off
% tidecorr : off
% tropo opt : sbas
% ephemeris : broadcast+sbas
% navi sys : gps sbas
% antenna1 : ( 0.0000 0.0000 0.0000)
I have taken the average x,y,z and entered that into RTKPost.
I have changed the setting so that L1 is used. And set it to static. I have
no settings for the antennas.
I am not sure what you mean by " sbs is facultative"
I am still not getting a good fix.
Regards,
MacSam
-----Original Message-----
From: dan marcotte [via Open Source GPS-related discussion and support]
[mailto:ml-node+s1099874n7573263h27 at n2.nabble.com]
Sent: 03 August 2015 16:48
To: macSam <mike.mcloughlin at rockmate.com>
Subject: Re: RTKLIB RTKCONV RTKPOST
Hello MacSam
the Neo 6P are capable of cm accuracy assuming that the base is less than
10km and your have raisonnable quality antennas...
you need:
1. to set up the positionning mode to either cinematic or static 2. enter
the precise position of the base station including height
btw your device is L1 only
sbs is facultatif
and of course, it will not work if your base station is a bad reception
situation
If you reply to this email, your message will be added to the discussion
below:
http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/
RTKLIB-RTKCONV-RTKPOST-tp7573249p7573263.html
To unsubscribe from RTKLIB RTKCONV RTKPOST, click here
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com
/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=7573249&code=bWlrZS
5tY2xvdWdobGluQHJvY2ttYXRlLmNvbXw3NTczMjQ5fC01MzM5MjYzNTc=> .
NAML
/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemai
l.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.N
abbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_sub
scribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_ins
tant_email%21nabble%3Aemail.naml>
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-RTKCONV-RTKPOST-tp7573249p7573265.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150812/110aa02e/attachment.html>
More information about the FOSS-GPS
