[FOSS-GPS] RTKLIB RTKCONV RTKPOST
dan marcotte jdanielmarcotte at yahoo.ca
Tue Aug 18 07:49:00 PDT 2015
RTKPOST
Options / Setting 1 / Positionning Mode : Static
Options / Positions / Base Station : Lat / Long / Height
even if you get a fix, the absolute accuracy of the rover
will not be better than the base
to achieve cm accuracy,
you need a base station with known precise coord.
and clear environnement
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-RTKCONV-RTKPOST-tp7573249p7573266.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
