[FOSS-GPS] RTKLIB RTKCONV RTKPOST
macSam
mike.mcloughlin at rockmate.com
Tue Aug 18 08:31:47 PDT 2015
Thanks Dan,
After I run RTKPOST rover position quality is not showing up as dgps but as
float. Is that because they might be using different satellites?
Regards,
MacSam
From: dan marcotte [via Open Source GPS-related discussion and support]
[mailto:ml-node+s1099874n7573266h20 at n2.nabble.com]
Sent: 18 August 2015 15:49
To: macSam <mike.mcloughlin at rockmate.com>
Subject: RE: RTKLIB RTKCONV RTKPOST
RTKPOST
Options / Setting 1 / Positionning Mode : Static
Options / Positions / Base Station : Lat / Long / Height
even if you get a fix, the absolute accuracy of the rover
will not be better than the base
to achieve cm accuracy,
you need a base station with known precise coord.
and clear environnement
_____
If you reply to this email, your message will be added to the discussion
below:
http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/
RTKLIB-RTKCONV-RTKPOST-tp7573249p7573266.html
To unsubscribe from RTKLIB RTKCONV RTKPOST, click here
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com
/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=7573249&code=bWlrZS
5tY2xvdWdobGluQHJvY2ttYXRlLmNvbXw3NTczMjQ5fC01MzM5MjYzNTc=> .
/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemai
l.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.N
abbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_sub
scribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_ins
tant_email%21nabble%3Aemail.naml> NAML
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-RTKCONV-RTKPOST-tp7573249p7573267.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150818/83efe7c0/attachment.html>
More information about the FOSS-GPS
