[FOSS-GPS] rtklib / rnx2rtkp gps/glonass
Greger Burman
gb at moroco.se
Wed Aug 19 04:36:13 PDT 2015
Hello MattOnWeb!
So just to be clear... Were you able to get better results with GPS+GLONASS
compared to GPS only? If so, then how?
The reason I ask is because I experience the same problem. I get better
results with GPS only, compared to GPS+GLONASS (e.g. 8+8 satellites). I
have only used separated RINEX NAV files (.15N and .15G).
cheers
2015-07-30 15:33 GMT+02:00 MattOnWeb <m.lonchay at outlook.com>:
> Thank's again for your help.
> No, but there are some personal modifications I have to apply to the C code
> (for the purpose of my research only) before recompiling and using the
> rnx2rtkp.exe binary from a command line.
> So although I can use the binaries and the interface from the patch (by
> pasting the new files), the set of C scripts need to be compilable again
> for
> my purpose.
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/rtklib-rnx2rtkp-gps-glonass-tp7573251p7573259.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Greger Buman
MoRoCo AB
+46702623081
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150819/29bde267/attachment.html>
More information about the FOSS-GPS
