[FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
jdanielmarcotte at yahoo.ca
Fri Dec 11 07:16:40 PST 2015
hello gto
there is another possibility if you use only one base station:install strsvr on an intermediary computer instead of a caster.Of course you still need a static IP or no-ip set-up (or using the temporary ip for testing)and ask your ISP to open 3 ports:one for the incoming stream ex.: 5000 one for the outgoing stream ex.: 5001and one for a vnc server ex.: 5900
base / rtkgps+ / output tcpclient to ip_of_server:5000
intermediary strsvrinput: tcpserver 5000output: tcpserver 5001populate the coordinates of the base station
rover / rtkgps+ / input base station ip_of_server:5001populate the coordinates of the base station(if not rtcm format)
:-) jdm
De : gto234 <mersota at hotmail.com>
À : foss-gps at lists.osgeo.org
Envoyé le : jeudi 10 décembre 2015 11h34
Objet : Re: [FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
In my region the ISP's does not change the IP often. It is dynamic IP but
essentially is static.
For now I want to test the base-rover scenario i described before and if it
suit my needs I may switch to static IP.
So you suggest I try another NTRIP Caster.
If you can send me something to test I will.
Thanks.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKGPS-using-RTCM-with-GPS-GLONASS-not-working-tp7573332p7573373.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20151211/e06adc99/attachment.html>
More information about the FOSS-GPS
