[FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
gto234 mersota at hotmail.com
Thu Dec 10 08:34:50 PST 2015
In my region the ISP's does not change the IP often. It is dynamic IP but
essentially is static.
For now I want to test the base-rover scenario i described before and if it
suit my needs I may switch to static IP.
So you suggest I try another NTRIP Caster.
If you can send me something to test I will.
Thanks.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKGPS-using-RTCM-with-GPS-GLONASS-not-working-tp7573332p7573373.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
