[FOSS-GPS] Commands to use novatel OEMV6 as rover with rtknavi
Cocute
cocute at gmail.com
Thu Feb 5 00:42:10 PST 2015
Thanks,
but my ask is?
rtknavi in rover kinematic fix and hold mode use this commands :
log ionutcb onnew
log rawephemb onnew
log gloephemerisb onnew
log rawwaasframeb onnew
or only need this:
log rangecmpb ontime 0.1
(with only this command works, but i dont now if lost some function)
thanks
El 05/02/2015 a las 4:41, Tomoji Takasu escribió:
> Refer rtklib/data/oem6_raw_1hz.cmd.
> To modify the update interval, edit the last field of
> the line:
>> log rangecmpb ontime 1
> Tomoji TAKASU
> From: "cocute" <cocute at gmail.com>
> Sent: Thursday, February 5, 2015 7:30 AM
> To: <foss-gps at lists.osgeo.org>
> Subject: [FOSS-GPS] Commands to use novatel OEMV6 as rover with rtknavi
>> Hello,
>> to use novatel in rtklib as rover with rtknavi i need all this commands?
>> log ionutcb onnew
>> log rawephemb onnew
>> Or only is need this?
>> Thanks
>> View this message in context:
>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Commands-to-use-novatel-OEMV6-as-rover-with-rtknavi-tp7573129.html
>> Sent from the Open Source GPS-related discussion and support mailing
>> list archive at Nabble.com.
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> subscription
More information about the FOSS-GPS
