[FOSS-GPS] Commands to use novatel OEMV6 as rover with rtknavi
Tomoji Takasu ttaka at yk.rim.or.jp
Thu Feb 5 00:48:50 PST 2015
> rtknavi in rover kinematic fix and hold mode use this commands :
The answer is it depends on your settings.
Tomoji TAKASU
Sent: Thursday, February 5, 2015 5:42 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] Commands to use novatel OEMV6 as rover with rtknavi
> Thanks,
> but my ask is?
> log ionutcb onnew
> log rawephemb onnew
> log gloephemerisb onnew
> log rawwaasframeb onnew
> or only need this:
> log rangecmpb ontime 0.1
>  (with only this command works, but i dont now if lost some function)
> thanks
> El 05/02/2015 a las 4:41, Tomoji Takasu escribió:
>> Refer rtklib/data/oem6_raw_1hz.cmd.
>> To modify the update interval, edit the last field of
>> the line:
>>> log rangecmpb ontime 1
>> Tomoji TAKASU
>> From: "cocute" <cocute at gmail.com>
>> Sent: Thursday, February 5, 2015 7:30 AM
>> To: <foss-gps at lists.osgeo.org>
>> Subject: [FOSS-GPS] Commands to use novatel OEMV6 as rover with rtknavi
>>> Hello,
>>> to use novatel in rtklib as rover with rtknavi i need all this commands?
>>> log ionutcb onnew
>>> log rawephemb onnew
>>> Or only is need this?
>>> Thanks
>>> View this message in context:
>>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Commands-to-use-novatel-OEMV6-as-rover-with-rtknavi-tp7573129.html
>>> Sent from the Open Source GPS-related discussion and support mailing
>>> list archive at Nabble.com.
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>> subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
> subscription
More information about the FOSS-GPS mailing list
