[FOSS-GPS] RTKPos processing options
António Pestana
afsm.pestana at gmail.com
Wed Feb 11 04:25:34 PST 2015
I´m testing RTKPos processing options but I'm having trouble to fully
understand the meaning of some of the processing options available. I want
to compute de position of a "rover" (actually it is fixed to the ground...)
using another receiver as a base station. I'm able to collect (up to 20 Hz)
code and phase data from both GPS and GLONASS.
I'm looking for answers to the following questions:
a) What are the differences between position modes Single, Static,
Kinematic and DGPS/ DGNSS?
b) What are the differences between Integer Ambiguity Resolution options
Continuous, Instantaneous and Fix&Hold?
I have a medium-level understanding of Kalman filtering and I'm aware of
the integer ambiguity resolution problem.
Can you help me?
Regards
Antonio
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150211/fe7abfb4/attachment.html>
More information about the FOSS-GPS
