[FOSS-GPS] How to configure RTKLIB android with NV08C-CSM chip?
arwooldridge@googlemail.com
arwooldridge at googlemail.com
Thu Jan 15 02:14:16 PST 2015
If in doubt read all the documentation!
Beware though the USB is via FTDI serial to usb converter. You must therefore have the correct drivers installed. The system should then identify the two serial ports correctly. Note that unlike usb interface you must select the correct baud rate parity and stop bits or you will not communicate. Beware also the parity is ODD!
Regards Anthony
Sent from my HTC
----- Reply message -----
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] How to configure RTKLIB android with NV08C-CSM chip?
Date: Wed, Jan 14, 2015 21:04
I think problem is,
NV08C-CSM have two COM ports:
COM 11 for nemea
COM 12 for raw
in rtklib pc versión i choose COM12 and all OK,
But in android version only select USB,
and i think it connect to COM11 Nmea
i dont now what is parameter to select COM12 ¿?
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/How-to-configure-RTKLIB-android-with-NV08C-CSM-chip-tp7573099p7573101.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150115/90ac9b9a/attachment.html>
More information about the FOSS-GPS
