[FOSS-GPS] How to configure RTKLIB android with NV08C-CSM chip?
Danny Miller
dannym at austin.rr.com
Thu Jan 15 02:54:52 PST 2015
Beware that standard baud rates (9600) can easily end up in buffer
overrun due to more data every second than 9600 baud can handle. And at
first, with only a few satellites acquired, the data may be intact, then
have problems once many sats are acquired and more data needs to be sent.
You need to configure the NV08C for 57600 baud and "save" the config.
I'm not sure if that requires the battery to be in place or not. But
you want this config to stay persistent because you're gonna have your
FTDI chip on a fixed configuration for 57600.
Danny
On 1/15/2015 4:14 AM, arwooldridge at googlemail.com wrote:
> If in doubt read all the documentation!
> Beware though the USB is via FTDI serial to usb converter. You must
> therefore have the correct drivers installed. The system should then
> identify the two serial ports correctly. Note that unlike usb
> interface you must select the correct baud rate parity and stop bits
> or you will not communicate. Beware also the parity is ODD!
> Regards Anthony
> Sent from my HTC
> ----- Reply message -----
> From: "cocute" <cocute at gmail.com>
> To: <foss-gps at lists.osgeo.org>
> Subject: [FOSS-GPS] How to configure RTKLIB android with NV08C-CSM chip?
> Date: Wed, Jan 14, 2015 21:04
> I think problem is,
> NV08C-CSM have two COM ports:
> COM 11 for nemea
> COM 12 for raw
> in rtklib pc versión i choose COM12 and all OK,
> But in android version only select USB,
> and i think it connect to COM11 Nmea
> i dont now what is parameter to select COM12 ¿?
> View this message in context:http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/How-to-configure-RTKLIB-android-with-NV08C-CSM-chip-tp7573099p7573101.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visithttp://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, checkhttp://wiki.osgeo.org/wiki/FOSS-GPS
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150115/54af74d1/attachment.html>
More information about the FOSS-GPS
