[FOSS-GPS] RTKLIB Output Solutions in Moving Base and Kinematic Mode
arwooldridge arwooldridge at googlemail.com
Thu Jan 15 02:52:11 PST 2015
Its the final RTK solution of the rover position, whether fixed, float
or single.
It reverts to single if the base station is lost.
You could get the single NMEA rover position direct from the receiver if
you should need it.
An interesting question is why is the single solution from the RTKlib
when base station is lost, so much worse than the single solution direct
from the receiver in most cases, even if SBS is selected in RTKlib.
This is a scenario in which it may be better to revert to the receiver's
own single NMEA solution once base station is lost.
Anthony
On 15/01/2015 10:29, bjorn.spockeli wrote:
> Hi,
> when RTKLIB is operating in Moving Base and Kinematic mode, is the NMEA
> solution the single position of the rover or is it the starting point of the
> baseline vector ?
> Bjørn
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-Output-Solutions-in-Moving-Base-and-Kinematic-Mode-tp7573103.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
