[FOSS-GPS] R: post-processing in RTKLib
julio menezes
yjmenezes at yahoo.com.br
Mon Jan 19 06:43:46 PST 2015
Hi Antonella Marsico
Em seg, 19/1/15, Antonella Marsico <antonella.marsico at uniba.it> escreveu:
Assunto: [FOSS-GPS] R: post-processing in RTKLib
Para: "'Open Source GPS-related discussion and support'" <foss-gps at lists.osgeo.org>
Data: Segunda-feira, 19 de Janeiro de 2015, 11:28
For the reference station
all data are ok, but what does "reference
distance" mean?
my
post-processing worked well and in the RTKPLOT (Gnd Trk) I
see that my
data look like Kinematic survey.
I suppose that the coordinates that I need
are those of the ORI in the statistic, since I
need coordinates of one
point: is it
correct?
Antonella Marsico, PhD
1- the distance from your unknown location to reference base location . L1 receivers it must be below 15Km to get good results.
2- Options: you can select ALL or Single ( output panel ), if ALL, you will see as you say, Q2=float ( orange ) and Q1=fixed ( final solution ). the solution converge
Check the output reporter text file. ( POS extension by default )
you will have a long file if ALL or just one position if you select Single.
regards,
julio menezes
More information about the FOSS-GPS
