[FOSS-GPS] R: R: post-processing in RTKLib
Antonella Marsico antonella.marsico at uniba.it
Tue Jan 20 01:13:52 PST 2015
Ok, the reference distance is 10,5km...
I selected Single in the output panel and I get just one position with
Q=2:1(100%) in orange: is it right? in the RTKPLOT I don't see any data
about Nsat or position or velocity... Is it correct?
Thank you very much for all.
Antonella Marsico, PhD
Dipartimento di Scienze della Terra e Geoambientali
Università degli Studi di Bari "Aldo Moro"
via E. Orabona 4 - 70125 Bari
email: antonella.marsico at uniba.it
skype: antonellamarsico
-----Messaggio originale-----
Da: foss-gps-bounces at lists.osgeo.org
[mailto:foss-gps-bounces at lists.osgeo.org] Per conto di julio menezes
Inviato: lunedì 19 gennaio 2015 15.44
A: Open Source GPS-related discussion and support
Oggetto: Re: [FOSS-GPS] R: post-processing in RTKLib
Hi  Antonella Marsico
Em seg, 19/1/15, Antonella Marsico <antonella.marsico at uniba.it> escreveu:
 Assunto: [FOSS-GPS] R:  post-processing in RTKLib
 Para: "'Open Source GPS-related discussion and support'"
<foss-gps at lists.osgeo.org>
 Data: Segunda-feira, 19 de Janeiro de 2015, 11:28
 For the reference station
 all data are ok, but what does "reference  distance" mean?
 my
 post-processing worked well and in the RTKPLOT (Gnd Trk) I  see that my
data look like Kinematic survey.
 I suppose that the coordinates that I need  are those of the ORI in the
statistic, since I  need coordinates of one
 point: is it
 correct?
1- the distance from your unknown location to reference base location .  L1
receivers it must be below 15Km to get good  results.
2- Options:  you can select ALL or Single ( output panel ), if ALL, you will
see as you say, Q2=float ( orange ) and Q1=fixed ( final solution ). the
solution converge Check the output reporter text file. ( POS extension by
default ) you will have a long file if ALL or just one position if you
select Single.
regards,
julio menezes
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
subscription For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
