[FOSS-GPS] R: R: post-processing in RTKLib
julio menezes
yjmenezes at yahoo.com.br
Tue Jan 20 02:31:12 PST 2015
Hi Antonella Marsico ,
Em ter, 20/1/15, Antonella Marsico <antonella.marsico at uniba.it> escreveu:
Assunto: [FOSS-GPS] R: R: post-processing in RTKLib
Para: "'Open Source GPS-related discussion and support'" <foss-gps at lists.osgeo.org>
Data: Terça-feira, 20 de Janeiro de 2015, 7:13
Ok, the reference
distance is 10,5km...
I selected Single in
the output panel and I get just one position with
Q=2:1(100%) in orange: is it right? in the
RTKPLOT I don't see any data
about Nsat
or position or velocity... Is it correct?
Thank you very much for all.
You should get Q=1 fixed unless you have:
a) short occupation time, try sessions of 1 hour, repeat to confirm.
b) blocked signal by buildings or trees,
c) some wrong settings
d) some hardware failure ( cables ... )
the Nsat is reported inside POS file, "ns" field, near "Q" field.
if you don't mind, you could send me your collected data and a short description about your receiver+antenna and field conditions.
regards,
julio menezes
More information about the FOSS-GPS
