[FOSS-GPS] R: R: R: post-processing in RTKLib
Antonella Marsico
antonella.marsico at uniba.it
Tue Jan 20 06:33:10 PST 2015
I think the problem is in the short time... I will try again with a longer
session.
Thanks
Antonella Marsico, PhD
Dipartimento di Scienze della Terra e Geoambientali
Università degli Studi di Bari "Aldo Moro"
via E. Orabona 4 - 70125 Bari
email: antonella.marsico at uniba.it
skype: antonellamarsico
-----Messaggio originale-----
Da: foss-gps-bounces at lists.osgeo.org
[mailto:foss-gps-bounces at lists.osgeo.org] Per conto di julio menezes
Inviato: martedì 20 gennaio 2015 11.31
A: Open Source GPS-related discussion and support
Oggetto: Re: [FOSS-GPS] R: R: post-processing in RTKLib
Hi Antonella Marsico ,
Em ter, 20/1/15, Antonella Marsico <antonella.marsico at uniba.it> escreveu:
Assunto: [FOSS-GPS] R: R: post-processing in RTKLib
Para: "'Open Source GPS-related discussion and support'"
<foss-gps at lists.osgeo.org>
Data: Terça-feira, 20 de Janeiro de 2015, 7:13
Ok, the reference
distance is 10,5km...
I selected Single in
the output panel and I get just one position with
Q=2:1(100%) in orange: is it right? in the RTKPLOT I don't see any data
about Nsat or position or velocity... Is it correct?
Thank you very much for all.
You should get Q=1 fixed unless you have:
a) short occupation time, try sessions of 1 hour, repeat to confirm.
b) blocked signal by buildings or trees,
c) some wrong settings
d) some hardware failure ( cables ... )
the Nsat is reported inside POS file, "ns" field, near "Q" field.
if you don't mind, you could send me your collected data and a short
description about your receiver+antenna and field conditions.
regards,
julio menezes
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
subscription For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
