[FOSS-GPS] rtklib / rnx2rtkp gps/glonass
Dimitris Psychas
psxdimitris at hotmail.com
Wed Jul 29 14:47:01 PDT 2015
Dear Matt,
I had the same problem when I first installed the package RTKLIB.
What you have to do is to download and install the latest patch of RTKLIB, which you can easily find in the tab "Support" in website www.rtklib.com. When you apply the patch and use both GPS and GLO observations, you will see that GLO observations are supported.
Best regards,
Dimitrios V. Psychas
> Date: Wed, 29 Jul 2015 14:11:10 -0700
> From: m.lonchay at outlook.com
> To: foss-gps at lists.osgeo.org
> Subject: [FOSS-GPS] rtklib / rnx2rtkp gps/glonass
> Hello everyone,
> I am currently discovering the possibilities of RTKLib (big thank you to the
> conceivers by the way) in the context of my thesis in satellite navigation.
> I am currently testing the software on mixed GPS/GLONASS Observation and
> Navigation files (brdm). But, for some reasons, it happens that the solution
> (SPP or PPP) is worst when using both GPS and GLO than GPS only (or GLO
> only). Also, the number of satellites used (and the DOP) does not seem to be
> better when using both GPS and GLONASS which is, of course, against what we
> would expect. 25 satellites are frequently available in the RINEX
> Observation file, but only ~10 satellites seem to be used by RTKLib for each
> epoch.
> I was wondering if someone here would be used to exploiting RTKLib with
> multi-GNSS for positioning and if there would be an option I missed (CFG:
> pos1-navsys =15 (1 GPS + 4 GLO)).
> Many thanks in advance for your help,
> Matt
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/rtklib-rnx2rtkp-gps-glonass-tp7573251.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150730/bb4261b9/attachment.html>
More information about the FOSS-GPS
