[FOSS-GPS] how to use *.sp3, *.clk, *.yyi in rtkpost with Kinematic mode
Anders Wallin anders.e.e.wallin at gmail.com
Wed Mar 18 14:09:18 PDT 2015
FWIW some screenshots from when I tried a few different programs for static
PPP:
http://www.anderswallin.net/2013/12/comparing-gps-ppp-solutions/
in many cases I found ESA gLab more user-friendly with the GUI/dialogs
guiding the user through the various stages. You could try it:
http://gage.upc.edu/gLAB
I've only done PPP solutions from dual-frequency L1/L2 receivers that
produce RINEX files. Not familiar at with IONEX files, since those are not
needed with L1/L2-receivers.
Anders
On Wed, Mar 18, 2015 at 8:29 PM, Yanqing Hou <fishloveocean at gmail.com>
wrote:
> Hi all,
> I want to use the precise ephemeris (*.sp3), precise clock correction
> (*.clk), and ionospheric corrections (*.yyi) from IGS in resolving a
> baseline of about 200km. I tried to include the sp3 and clk files in the
> input dialogue, and chose the options in setting1 as:
> Ionosphere Correction: IONEX TEC,
> Satellite Ephemeris/Clock: Precise
> I used only GPS constellation and continous mode to resolve ambiguities,
> but the precision of the baseline is still very low: the standard deviation
> of N/E/U is around 0.5m in each direction. I assume I did not use the sp3,
> clk, and ionex files correctly, because other people can have much better
> precision than mine with other softwares.
> Is there anybody who has an experience of using these IGS products to
> process the baseline solutions?
> Thanks,
> Yanqing
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150318/1b7fede1/attachment.html>
More information about the FOSS-GPS mailing list
