[FOSS-GPS] Ublox NEO-M8N no GLONASS in RTKRCV
Stefan Weber BFH webes14 at bfh.ch
Wed May 13 11:25:11 PDT 2015
Hello everyone
I am trying to get a Ublox NEO-M8N working with rtkrcv on linux.
Connected over USB, I like to get GPS and GLONASS working in Single mode
and later in kinematic mode.
I set the "pos1-navsys  =5  # (1:gps+2:sbas+4:glo+8:gal+16:qzs+32:comp)"
for GPS and GLONASS, but I only get GPS Satellites.
I used on the same time, with the same antenna, at the same place a
second Ublox NEO-M8N also connected over USB on a
WIN7 PC with RTKNAVI, and there I got with similar settings GPS and
GLONASS Satellites.
So if there is not a software bug in rtkrcv, in my opinion there should
be GPS and GLONASS Satellites visible if I type
  "satellites 1". The numbers of satellites if I type "status 1" is
equal to the numbers of GPS Satellites only in RTKNAVI at the same time.
Or is there something wrong in my settings?
As configuration file I am using the ubx_m8n_glo_raw_1hz.conf, and the
rtk_kinematik.conf you find below. I used rtklib 2.4.1
p11.<https://github.com/tomojitakasu/RTKLIB/commit/b3d1441f24dc73bb6b0cb6138233349053692c73>
It would be nice, if someone with a Ublox NEO-M8N could retest this.
Thanks
Regards
Stefan
Student Switzerland
__________________________________________________________________________
!UBX CFG-GNSS 0 32 32 1 3 16 16 0 0
!UBX CFG-GNSS 0 32 32 1 6 16 16 0 1
!UBX CFG-MSG 3 16 0 0 0 1 0 0
!UBX CFG-MSG 3 15 0 0 0 1 0 0
!UBX CFG-MSG 1 32 0 0 0 1 0 0
!UBX CFG-MSG 3 16 0 0 0 0 0 0
!UBX CFG-MSG 3 15 0 0 0 0 0 0
!UBX CFG-MSG 1 32 0 0 0 0 0 0
rtk_kinematik.conf
# rtkrcv options (2010/08/12 07:12:16, v.2.4.0)
console-passwd     =admin
console-timetype   =gpst       # (0:gpst,1:utc,2:jst,3:tow)
console-soltype    =dms        # (0:dms,1:deg,2:xyz,3:enu,4:pyl)
console-solflag    =1          # (0:off,1:std+2:age/ratio/ns)
inpstr1-type       =serial     #
(0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http)
inpstr2-type       =serial     #
inpstr3-type       =off        #
inpstr1-path       =ttyACM0:230400:8:n:1:off
inpstr2-path       =ttyUSB2:115200:8:n:1:off
inpstr3-path       =
inpstr1-format     =ubx       #
(0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,14:sp3)
inpstr2-format     =rtcm3       #
inpstr3-format     =sp3        #
inpstr2-nmeareq    =off        # (0:off,1:latlon,2:single)
inpstr2-nmealat    =0          # (deg)
inpstr2-nmealon    =0          # (deg)
outstr1-type       =serial        #
(0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
outstr2-type       =off        #
outstr1-path       =ttyUSB0:115200:8:n:1:off
outstr2-path       =sol2_%Y%m%d%h%M.pos
outstr1-format     =nmea        # (0:llh,1:xyz,2:enu,3:nmea)
outstr2-format     =nmea       # (0:llh,1:xyz,2:enu,3:nmea)
logstr1-type       =off        #
logstr2-type       =off        #
logstr3-type       =off        #
logstr1-path       =rov_%Y%m%d%h%M.log
logstr2-path       =ref_%Y%m%d%h%M.log
logstr3-path       =cor_%Y%m%d%h%M.log
misc-svrcycle      =10         # (ms)
misc-timeout       =10000      # (ms)
misc-reconnect     =10000      # (ms)
misc-nmeacycle     =5000       # (ms)
misc-buffsize      =32768      # (bytes)
misc-navmsgsel     =all      # (0:all,1:rover,1:base,2:corr)
misc-startcmd      =
misc-stopcmd       =
file-cmdfile1      =../data/ubx_m8n_glo_raw_1hz.cmd
file-cmdfile2      =
file-cmdfile3      =
pos1-posmode       =single     #
(0:single,1:dgps,2:kinematic,3:static,4:movingbase,5:fixed,6:ppp-kine,7:ppp-static)
pos1-frequency     =1         # (1:l1,2:l1+l2,3:l1+l2+l5)
pos1-soltype       =forward    # (0:forward,1:backward,2:combined)
pos1-elmask        =0         # (deg)
pos1-snrmask       =0          # (dBHz)
pos1-dynamics      =off        # (0:off,1:on)
pos1-tidecorr      =off        # (0:off,1:on)
pos1-ionoopt       =brdc       #
(0:off,1:brdc,2:sbas,3:dual-freq,4:est-stec)
pos1-tropopt       =saas       #
(0:off,1:saas,2:sbas,3:est-ztd,4:est-ztdgrad)
pos1-sateph        =brdc    #
(0:brdc,1:precise,2:brdc+sbas,3:brdc+ssrapc,4:brdc+ssrcom)
pos1-exclsats      =           # (prn ...)
pos2-armode        =fix-and-hold        #
(0:off,1:continuous,2:instantaneous,3:fix-and-hold)
pos2-gloarmode     =on        # (0:off,1:on,2:autocal)
pos2-arthres       =1
pos2-arlockcnt     =0
pos2-arelmask      =0          # (deg)
pos2-aroutcnt      =5
pos2-arminfix      =10
pos2-slipthres     =0.05       # (m)
pos2-maxage        =30         # (s)
pos2-rejionno      =30         # (m)
pos2-niter         =1
pos2-baselen       =0          # (m)
pos2-basesig       =0          # (m)
out-solformat      =llh        # (0:llh,1:xyz,2:enu,3:nmea)
out-outhead        =off        # (0:off,1:on)
out-outopt         =off        # (0:off,1:on)
out-timesys        =gpst       # (0:gpst,1:utc,2:jst)
out-timeform       =hms        # (0:tow,1:hms)
out-timendec       =3
out-degform        =deg        # (0:deg,1:dms)
out-fieldsep       =
out-height         =ellipsoidal # (0:ellipsoidal,1:geodetic)
out-geoid          =internal   #
(0:internal,1:egm96,2:egm08_2.5,3:egm08_1,4:gsi2000)
out-solstatic      =all        # (0:all,1:single)
out-nmeaintv1      =0          # (s)
out-nmeaintv2      =0          # (s)
out-outstat        =off        # (0:off,1:state,2:residual)
stats-errratio     =100
stats-errphase     =0.003      # (m)
stats-errphaseel   =0.003      # (m)
stats-errphasebl   =0          # (m/10km)
stats-errdoppler   =1          # (Hz)
stats-stdbias      =30         # (m)
stats-stdiono      =0.03       # (m)
stats-stdtrop      =0.3        # (m)
stats-prnaccelh    =10          # (m/s^2)
stats-prnaccelv    =10        # (m/s^2)
stats-prnbias      =0.0001     # (m)
stats-prniono      =0.001      # (m)
stats-prntrop      =0.0001     # (m)
stats-clkstab      =5e-12      # (s/s)
ant1-postype       =llh        #
(0:llh,1:xyz,2:single,3:posfile,4:rinexhead,5:rtcm)
ant1-pos1          =0          # (deg|m)
ant1-pos2          =0          # (deg|m)
ant1-pos3          =0          # (m|m)
ant1-anttype       =
ant1-antdele       =0          # (m)
ant1-antdeln       =0          # (m)
ant1-antdelu       =0          # (m)
ant2-postype       =llh        #
ant2-pos1          =          # (deg|m)
ant2-pos2          =          # (deg|m)
ant2-pos3          =          # (m|m)
ant2-anttype       =
ant2-antdele       =0          # (m)
ant2-antdeln       =0          # (m)
ant2-antdelu       =0          # (m)
misc-timeinterp    =off        # (0:off,1:on)
misc-sbasatsel     =0          # (0:all)
file-satantfile    =
file-rcvantfile    =
file-staposfile    =
file-geoidfile     =
file-dcbfile       =
file-tempdir       =temp
file-geexefile     =
file-solstatfile   =
file-tracefile     =
More information about the FOSS-GPS mailing list
