[FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
gto234 mersota at hotmail.com
Sun Nov 15 03:50:41 PST 2015
Can anyone help me setup the base station on the RTKGPS+? It is a novatel
oemv board.
I set the input streams as follows but the result is single mode as if not
receiving corrections.
Input Rover
Format: Novatel OEMV/4
Antenna: none
Commands at startup/shutdown: choose the "oem4_raw_1hz.cmd"
Receiver option: none (what is this field?)
Input Base
Antenna: none
Base station position: enter Lat/Lon/Height manually, there is no "average"
option.
Transmit GPGGA to Base Station: OFF (since it is not connected to NTRIP
caster)
What am I doing wrong?
Tried also the RTCM3 Format on the Base as follows:
Input Base
Format: RTCM3
Antenna: none
Commands at startup/shutdown: choose the "oem4_rtcm3_1hz.cmd"
Base station position: RTCM Antenna position
caster)
This setup results in same problem discribed before with only GLONASS
satellites in the solution.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKGPS-using-RTCM-with-GPS-GLONASS-not-working-tp7573332p7573336.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
