[FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
    gto234
    mersota at hotmail.com
    Fri Nov 13 23:45:31 PST 2015
Thanks for the reply.
The Sokkia firmware is not RTK-capable and also it is a discontinued model
so i can't upgrade in order to use it directly with SurvCE.
I prefer to use the RTKLIB engine with the raw data and output the solution
to SurvCE if it is possible. I am testing it.
But the problem is that rtkgps+ can't see the GPS sats if i select a GPS+GLO
mountpoint. It sees only the GLONASS sats! It must be a bug!
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKGPS-using-RTCM-with-GPS-GLONASS-not-working-tp7573332p7573335.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
