[FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
David Kelley
DavidKelley at ITSware.net
Thu Nov 19 12:16:43 PST 2015
gto234:
I also tired with the RTK+ version this morning, could not get anything
to work, even using the known good stream below.
Nothing now seem to work with the RTK+ tool, not even single autonomous
mode. From what you said below, and the last built commit stamp (Oct
2014), this all comes down to the leap second issue.
I have found the RTK+ tool very handy in the past to quickly show people
what RTKLIB can do and how to grab a caster stream. It make a good
"elevator talk" item if you like. Any word on when the author might
update things or what other may have patched copy? Of does this depend
on a chain of events where RTK+ needs Ronan LE MEILLAT to first get
Alexey Illarionov to patch his copy of Tomoji Takasu's RTKLIB original
source? The tool chain here (for lack of a better term) is confusing to me.
> A member sent me the RTKGPS+ version based on the patch 11 of RTKLIB
If said member cares to, I am sure I am not the only one who would want
such a thing.
> isn't any decent surveying software in android platform ...
Agree. If you are in the US, I strongly recommend the tool
"FinfAControl" for locating benchmarks when in the field.
A final question, what models of Bluetooth adapter or USB adapter do you
(or others) use to connect with?
We normally use laptops in the field or beagle boards, but I would like
to use my tablet for casual data logging. We have just gotten some cute
little Hemisphere P307 units here that I want to try this with.
Regards, David Kelley
On 11/19/2015 12:53 AM, gto234 wrote:
> Thanks David,
> I resolved the problem. The RTKGPS+ version on google play is outdated.
> A member sent me the RTKGPS+ version based on the patch 11 of RTKLIB and it
> worked like a charm!
> Using both GPS+GLO sats the rover fixes almost instantly either with NTRIP
> or my own base station (put on the same location of course!).
> The next step is to output the NMEA message via bluetooth to another device
> (Windows mobile) that has surveying software.
> Unfortunately there isn't any decent surveying software in android platform
> in order to accept the GPS mock location from RTKGPS+.
> Triggering this option on (Output GPS mock location) the RTKPGPS+ crashes. I
> hope this will be resolved in a future version.
> Thanks anyway!
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKGPS-using-RTCM-with-GPS-GLONASS-not-working-tp7573332p7573343.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
