[FOSS-GPS] RTKlib using GPS and GLONASS
Dimitris Psychas
psxdimitris at hotmail.com
Tue Sep 1 03:06:32 PDT 2015
Dear Jean-Charles,
have you installed the latest patch of RTKLIB ? If not, then this may be the problem with your GPS+GLO observation data.
Regards,
Dimitris
To: foss-gps at lists.osgeo.org
Date: Tue, 1 Sep 2015 08:53:27 +0000
Subject: [FOSS-GPS] RTKlib using GPS and GLONASS
I ‘m currently trying to use rtklib with GPS and GLONASS using L1 only signal, and I never got a fix.
Various tests were performed in :
post-processing mode (RTKPOST) in static and single, with various types of receiver (Ublox M8 raw data , and from national French CORS stations)
real-time (RTKNAVI) in static and single (Ublox M8 are used as raw data sources)
In GPS only all tests are OK, but when Glonass is activated no way to have a fix.
For each epoch, the returned error message is always :
point pos error (chi-square error nv=9 vv=882.4 cs=13.8)
Using RTKMonitor in RTKNAVI, I can see that residuals are very high.
Any ideas, or suggestions ?
Thanks for your help.
Jean-Charles
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150901/2eb2c430/attachment.html>
More information about the FOSS-GPS
