[FOSS-GPS] help with RTKPOST of GPS file please
anthony wooldridge
arwooldridge at googlemail.com
Sun Apr 17 13:13:32 PDT 2016
Just a thought re improving the fix:
If the airframe is pitching and rolling you may want to experiment
with a slightly higher elevation mask.
I see that the number of satelites varies from 9 to 5 in a fairly
erratic manner, possibly due to banking.
When a satellite comes in or out of the RTK solution you often get a
poor float solution.
Try maybe with an elevation mask ( in RTKlib) roughly equal to your
expected pitch or roll, then the number of satelites in the solution
should be more constant.
Too high an elevation mask and you will exclude too many satelites and
degrade the solution that way, so its a compromise.
The advantage of postprocessing is that you can try different mask
angles to see which works best.
Also another time you might consider a longer ( 10-15 minutes) standing
start to get a good static solution before getting airborne.
Regards Anthony
On 17/04/2016 19:47, ebennb wrote:
> Wow! Much better than I was able to get. Could you share the details of the
> parameters you used and which files you put where in the rtkpost program?
> Thanks!!
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/World-GNSS-Genius-Award-Competition-i-e-solve-an-RTKPOST-problem-please-tp7573460p7573463.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
