[FOSS-GPS] help with RTKPOST of GPS file please
Michele Bavaro
mic.bavaro at yahoo.co.uk
Sun Apr 17 15:07:10 PDT 2016
some further analysis of the rover obs shows 3 strange epochs with a
sharp 6 seconds (subframe) error, e.g.
> 2016 04 03 13 14 55.600000 0 11
*> 2016 04 03 13 14 40.800000 0 11**
*> 2016 04 03 13 14 56.000000 0 13
please check your converter as the rinex also reports several CRC
failures causing solution gaps
1. the Doppler shifts reveal a 2ppm error in the crystal which is
uncommon (to say the least) for LEA-6T.
2. the C/N0s peak at 40dBHz which is symptom of a very poor antenna.
3. the range inter-satellite differences shows incorrect range behaviour
for SV 8, 12, 20, 27 around 13:13 which is very odd, looking like the a
clock jump not being handled correctly on all satellites .. are we sure
this is a uBlox?
Pics here:
https://www.dropbox.com/sh/0kr0il17hd6t8qh/AADO4XndEaP2_J_Boofjl7paa?dl=0
Cheers,
Mic
On 17/04/2016 20:47, ebennb wrote:
> Wow! Much better than I was able to get. Could you share the details of the
> parameters you used and which files you put where in the rtkpost program?
> Thanks!!
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/World-GNSS-Genius-Award-Competition-i-e-solve-an-RTKPOST-problem-please-tp7573460p7573463.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160418/f10a78f9/attachment.html>
More information about the FOSS-GPS
