[FOSS-GPS] NV08C-CSM STRSVR settings.
Dhirendra singh
dskumher1968 at gmail.com
Mon Aug 8 19:30:06 PDT 2016
Hi everybody, I am using nv08c as the base & Hemisphere A100 cresent based
smart antenna as the rover. Base line distance 4.22 meter only. Both rover
& base on the same computer. Using SNIP NTRIP caster for sending &
receiving base data.Sky conditions are quite open. * I can get fix after 10
minutes when base & rover input is through serial ports only* but never get
fix on base input on NTRIP client. I will highly appreciate if anybody can
help me. I need some clarification regarding NV08c-csm RTCM messages also.
*1)- *RTKLIB manual says it supports RTCM V3 only but NV08C perhaps suppots
v2,2 only. So,in STRSVR for nv08c base to output RTCM msg. as ntrip server,
should I choose conversion option nv08c to RTCM 2 or 3 ?,What should be
the necessary message numbers(nv08c supports msg. 1,9,31 & 32 rtcm 2.2,
rtklib perhaps supports msg.18,19,17,3,22,14,16.)
*2)-*Should I choose the conversion option in strsvr from nv08c to rtcm at
all or keep the option unchecked .
*3)-*In RTKNAVI input stream window, which base input format should I
choose, RTCM 2 or 3 ?
*4)-* Should I choose NTRIP transmission option or radio data link option
for distances up to 5 km max.? I am attaching the screenshots for the
STRSVR window, I suspect that there is delay between the data transmission
from nv08c & RTCM output. Am I correct?
*5)-* Does current RTKLIB 2.4.2 with patch 11 support GLONASS & BEIDOU
satellite RTK correction ?
I am attaching the all relevant screenshots, kindly help me find cause of
no fix on NTRIP RTCM base input.
With best regards,
Dhirendra singh,
INDIA
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0015.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0016.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0017.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0018.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0019.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0020.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0021.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0022.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0023.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0024.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0025.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0026.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0027.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0028.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160809/d1bf240e/attachment-0029.png>
More information about the FOSS-GPS
