[FOSS-GPS] NV08C-CSM STRSVR settings.
Timo Juhani Lindfors timo.lindfors at iki.fi
Wed Aug 17 21:49:37 PDT 2016
Dhirendra singh <dskumher1968 at gmail.com> writes:
> Hi everybody, I am using nv08c as the base & Hemisphere A100 cresent based
> smart antenna as the rover. Base line distance 4.22 meter only. Both rover
> & base on the same computer. Using SNIP NTRIP caster for sending &
In case you are wondering, this email was delayed for 9 days since the
attachments were over the current 1 MB limit and the message had to be
manually accepted.
More information about the FOSS-GPS mailing list
