[FOSS-GPS] FoxtrotGPS - POI and other stuff
David Bannon
dbannon at internode.on.net
Thu Dec 15 01:40:13 PST 2016
Hi Folks, some questions about FoxtrotGPS ?
1. Reference is made to the poi.db, an sqlite database. Anyone know
where the format of that file is documented ? I might be able to work it
out from poi.c but not very keen.
2. My install of Foxtrot does not have any mention of poi in menus, is
that because the Ubuntu build chooses to not support poi ?
3. Assuming above, I grabbed source but the INSTALL file with building
instructions seems to have gone away. Those instructions exist on the
web site, should we make a new INSTALL file or remove reference to it
from README ?
4. In Contributions, the script, gpx2osm, line 26 says "...osm
version='0.5'...". OSM now requires version 0.6, fortunately, what we
are doing here is unchanged with the version boost so its a simple edit,
change 0.5 to 0.6
5. Do you want a "pull request" or what ever Launchpad uses to do 3 and
4 of this ?
David
More information about the FOSS-GPS
