[FOSS-GPS] RTKLIB\RTKNAVI 2.4.3.B15
arwooldridge@googlemail.com arwooldridge at googlemail.com
Fri Jul 29 13:37:13 PDT 2016
I had the same problem. but no solution yet.
Maybe try the Embarcardo forum also?
Possibly changes to built in library?
Let the community know if you find a solution.
Sent from my HTC
----- Reply message -----
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] RTKLIB\RTKNAVI 2.4.3.B15
Date: Fri, Jul 29, 2016 19:44
I’m trying to build RTKNAVI 2.4.3.b15 with Rad Studio 10.1 and I’m getting the following link errors:[ilink32 Error] Error: Unresolved external '__fastcall Vcl::Controls::TWinControl::GetDeviceContext(void *&)' referenced from H:\GITHUB\RTKLIB\APP\RTKNAVI\DEBUG_BUILD\NAVIMAIN.OBJ[ilink32 Error] Error: Unresolved external '__fastcall Vcl::Forms::TCustomForm::PaintWindow(void *)' referenced from H:\GITHUB\RTKLIB\APP\RTKNAVI\DEBUG_BUILD\NAVIMAIN.OBJ[ilink32 Error] Error: Unresolved external '__fastcall Vcl::Graphics::TFont::SetHandle(void * const)' referenced from H:\GITHUB\RTKLIB\APP\RTKNAVI\DEBUG_BUILD\GRAPH.OBJ[ilink32 Error] Error: Unable to perform linkThis started happening only with the last few pushes to the library. It was fine before that. Alas, I don’t see any direct references to these in the indicated source files nor do I know where they would be properly resolved from, etc. The solution is probably obvious to anyone more familiar with this build environment than I am, but I’m not that guy yet. Can anyone out there please clue me in?
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160729/3b0aa300/attachment.html>
More information about the FOSS-GPS mailing list
