[FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
Scott Harrison
scott at sharrison.net
Wed Jun 1 09:28:12 PDT 2016
Yes, port numbers in the range 0-1024 are well known ports and are
generally reserved for system or general purpose apps. On Linux systems
you need super user privileges to bind to those ports.
On Wed, Jun 1, 2016 at 4:46 AM, gto234 <mersota at hotmail.com> wrote:
> I found it, the problem was on the port number. For some reason the default
> port 1020 doesn't work.
> I changed the port to a bigger number e.g. 5000 and it TCP Server can read
> the stream and forward it to bluetooth.
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKGPS-using-RTCM-with-GPS-GLONASS-not-working-tp7573332p7573485.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160601/b807fafa/attachment.html>
More information about the FOSS-GPS
