[FOSS-GPS] Ublox M8T, unable to receive data
Jean-Michel Pouré jm at poure.com
Wed Mar 2 08:17:39 PST 2016
Le mercredi 02 mars 2016 à 08:56 -0700, xeee a écrit :
> After you run the command "rtkrcv -o ublox.conf" you need to write
> "start"
> Or instead you can run "rtkrcv -s -o ublox.conf"
> Don't forget to check the other command that you will probably
> need...
> http://www.rtklib.com/prog/manual_2.4.2.pdf
> Page 92 of the manual... status, stream, observ, navigate, satellite,
> error....
Yes, I did start using start command. Also, I read the manual before
posting on the mailing list. Status, observ, navigate and satellite are
simply empty. There is no error message.
status
Parameter                   : Value
rtklib version              : 2.4.2
rtk server thread           : 1083012864
rtk server state            : run
processing cycle (ms)       : 10
positioning mode            : single
frequencies                 : L1+L2
accumulated time to run     : 00:00:40.1
cpu time for a cycle (ms)   : 1
missing obs data count      : 0
bytes in input buffer       : 0,0
# of input data rover       :
obs(0),nav(0),gnav(0),ion(0),sbs(0),pos(0),dgps(0),ssr(0),err(0)
# of input data base        :
# of input data corr        :
# of rtcm messages rover    :
# of rtcm messages base     :
# of rtcm messages corr     :
solution status             : -
time of receiver clock rover: -
time sys offset (glo-gps)(s): 0.000000000
solution interval (s)       : 0.000
age of differential (s)     : 0.000
ratio for ar validation     : 0.000
# of satellites rover       : 0
# of satellites base        : 0
# of valid satellites       : 0
GDOP/PDOP/HDOP/VDOP         : 0.0,0.0,0.0,0.0
# of real estimated states  : 3
# of all estimated states   : 3
pos xyz single (m) rover    : 0.000,0.000,0.000
pos llh single (deg,m) rover: 0.00000000,0.00000000,0.000
vel enu (m/s) rover         : 0.000,0.000,0.000
pos xyz float (m) rover     : 0.000,0.000,0.000
pos xyz float std (m) rover : 0.000,0.000,0.000
pos xyz fixed (m) rover     : 0.000,0.000,0.000
pos xyz fixed std (m) rover : 0.000,0.000,0.000
pos xyz (m) base            : 6378137.000,0.000,0.000
ant type rover              :
ant delta rover             : 0.000 0.000 0.000
ant type base               :
ant delta base              : 0.000 0.000 0.000
pos llh (deg,m) base        : 0.00000000,0.00000000,0.000
vel enu (m/s) base          : 0.000,0.000,0.000
baseline length float (m)   : 0.000
baseline length fixed (m)   : 0.000
monitor port                : 0
Kind regards,
Jean-Michel
More information about the FOSS-GPS mailing list
