[FOSS-GPS] Ublox M8T, unable to receive data
agstrydom at gmail.com
Wed Mar 2 08:21:32 PST 2016
Hi Jean-Michel
Your gps is not configured to output raw data
Are you running at 10Hz?
I will forward you a configuration file that will run at 57200 baud, 10 Hz and give you raw data
Regards
Anton
Sent via my BlackBerry
-----Original Message-----
Sender: "FOSS-GPS" <foss-gps-bounces at lists.osgeo.org>Date: Wed, 02 Mar 2016 17:17:39
To: Open Source GPS-related discussion and support<foss-gps at lists.osgeo.org>
Reply-To: Open Source GPS-related discussion and support
Subject: Re: [FOSS-GPS] Ublox M8T, unable to receive data
Le mercredi 02 mars 2016 à 08:56 -0700, xeee a écrit :
> After you run the command "rtkrcv -o ublox.conf" you need to write
> "start"
> Or instead you can run "rtkrcv -s -o ublox.conf"
> Don't forget to check the other command that you will probably
> need...
> http://www.rtklib.com/prog/manual_2.4.2.pdf
> Page 92 of the manual... status, stream, observ, navigate, satellite,
> error....
Yes, I did start using start command. Also, I read the manual before
posting on the mailing list. Status, observ, navigate and satellite are
simply empty. There is no error message.
status
Parameter : Value
rtklib version : 2.4.2
rtk server thread : 1083012864
rtk server state : run
processing cycle (ms) : 10
positioning mode : single
frequencies : L1+L2
accumulated time to run : 00:00:40.1
cpu time for a cycle (ms) : 1
missing obs data count : 0
bytes in input buffer : 0,0
# of input data rover :
obs(0),nav(0),gnav(0),ion(0),sbs(0),pos(0),dgps(0),ssr(0),err(0)
# of input data base :
# of input data corr :
# of rtcm messages rover :
# of rtcm messages base :
# of rtcm messages corr :
solution status : -
time of receiver clock rover: -
time sys offset (glo-gps)(s): 0.000000000
solution interval (s) : 0.000
age of differential (s) : 0.000
ratio for ar validation : 0.000
# of satellites rover : 0
# of satellites base : 0
# of valid satellites : 0
GDOP/PDOP/HDOP/VDOP : 0.0,0.0,0.0,0.0
# of real estimated states : 3
# of all estimated states : 3
pos xyz single (m) rover : 0.000,0.000,0.000
pos llh single (deg,m) rover: 0.00000000,0.00000000,0.000
vel enu (m/s) rover : 0.000,0.000,0.000
pos xyz float (m) rover : 0.000,0.000,0.000
pos xyz float std (m) rover : 0.000,0.000,0.000
pos xyz fixed (m) rover : 0.000,0.000,0.000
pos xyz fixed std (m) rover : 0.000,0.000,0.000
pos xyz (m) base : 6378137.000,0.000,0.000
ant type rover :
ant delta rover : 0.000 0.000 0.000
ant type base :
ant delta base : 0.000 0.000 0.000
pos llh (deg,m) base : 0.00000000,0.00000000,0.000
vel enu (m/s) base : 0.000,0.000,0.000
baseline length float (m) : 0.000
baseline length fixed (m) : 0.000
monitor port : 0
Kind regards,
Jean-Michel
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
