Le mercredi 02 mars 2016 à 16:21 +0000, agstrydom at gmail.com a écrit : > Hi Jean-Michel > Your gps is not configured to output raw data > Are you running at 10Hz? > I will forward you a configuration file that will run at 57200 baud, > 10 Hz and give you raw data > Regards > Anton
