[FOSS-GPS] Ublox M8T, unable to receive data
Jean-Michel Pouré jm at poure.com
Wed Mar 2 08:44:35 PST 2016
Le mercredi 02 mars 2016 à 16:21 +0000, agstrydom at gmail.com a écrit :
> Hi Jean-Michel
> Your gps is not configured to output raw data
> Are you running at 10Hz?
> I will forward you a configuration file that will run at 57200 baud,
> 10 Hz and give you raw data
> Regards
> Anton
Dear Anton,
You are right, these are not RAW messages, my fault. I don't know
whether I am running at 10Hz or 1Hz. The only information from the
ventor:
NEO-M8T features:
    72-channel u-blox M8 engine GPS/QZSS L1 C/A, GLONASS L10F, BeiDou
B1 SBAS L1 C/A: WAAS, EGNOS, MSAS Galileo-ready E1B/C (subject to
Firmware upgrade)
    Nav. update rate Concurrent GNSS: up to 2 Hz
    Position accuracy 2.5 m CEP (Autonomous)
    Acquisition GPS & GLONASS GPS & BeiDou
Kind regards,
Jean-Michel
More information about the FOSS-GPS mailing list
