[FOSS-GPS] Ublox M8T, unable to receive data
Jean-Michel Pouré
jm at poure.com
Wed Mar 2 08:33:32 PST 2016
> Hi jean,
> Have you checked if it's sending raw data? . You can check it by
> using Ucenter in message configuration.
Besides, I can use str2str to fetch information:
stty -F /dev/ttyACM0 clocal raw
stty -F /dev/ttyACM0 clocal raw speed 115200
str2str -in file:///dev/ttyACM0#ubx -out file:///tmp/logfile.ubx
results in:
$GNTXT,01,01,02,u-blox AG - www.u-blox.com*4E
$GNTXT,01,01,02,HW UBX-M80xx 00080000 *43
$GNTXT,01,01,02,EXT CORE 2.30 (93796) Apr 8 2015 15:53:38*59
$GNTXT,01,01,02,ROM BASE 2.01 (75331) Oct 29 2013 13:28:17*44
$GNTXT,01,01,02,MOD NEO-M8T-0*60
$GNTXT,01,01,02,PROTVER 17.00*03
$GNTXT,01,01,02,GNSS OTP: GPS GLO, SEL: GPS GLO*67
$GNTXT,01,01,02,TIM RAW 1.02*5A
$GNTXT,01,01,02,ANTSUPERV=AC SD PDoS SR*3E
$GNTXT,01,01,02,ANTSTATUS=OK*25
$GNTXT,01,01,02,FIS 0xEF4015 (79189) found*2D
$GNTXT,01,01,02,LLC FFFFFFFF-FFFFFFED-FFFFFFFF-FFFFFFAE-FFFFFF69*3A
$GNRMC,163027.00,A,4936.67834,N,00306.20290,E,0.012,,020316,,,A*60
$GNVTG,,T,,M,0.012,N,0.022,K,A*3E
$GNGGA,163027.00,4936.67834,N,00306.20290,E,1,12,0.68,93.1,M,46.1,M,,*7
C
$GNGSA,A,3,24,12,15,19,17,10,18,25,,,,,1.27,0.68,1.08*1F
$GNGSA,A,3,74,72,82,71,65,83,84,,,,,,1.27,0.68,1.08*11
$GPGSV,4,1,13,06,04,095,,10,18,278,16,12,68,236,25,13,04,153,29*75
$GPGSV,4,2,13,14,24,314,15,15,34,179,23,17,26,046,25,18,10,247,33*7F
$GPGSV,4,3,13,19,43,077,25,22,04,337,,24,83,083,27,25,30,239,38*73
$GPGSV,4,4,13,32,19,316,25*41
$GLGSV,3,1,10,65,29,318,25,71,11,208,31,72,38,255,20,73,50,063,*67
$GLGSV,3,2,10,74,59,313,21,75,13,280,,80,05,085,,82,19,025,29*6C
$GLGSV,3,3,10,83,41,086,19,84,19,144,21*6A
$GNGLL,4936.67834,N,00306.20290,E,163027.00,A,A*7C
$GNZDA,163027.00,02,03,2016,00,00*7D
$GNRMC,163028.00,A,4936.67835,N,00306.20292,E,0.011,,020316,,,A*6F
More information about the FOSS-GPS
