[FOSS-GPS] ublox M8P
anthony wooldridge
arwooldridge at googlemail.com
Thu Mar 3 09:19:13 PST 2016
Interesting device ( the NS-HP) , but GPS only I think.
Satellite numbers often go below threshold, or optimum geometry, for RTK
when using GPS only.
Then you get a big jump reverting to single. So not good if you need
100% availability.
Glonass doesn't help initial lockon AFAIK ( if integer ambiguity is
switched off, at least in RTKlib) but might help hold an RTK solution
once found.
It would depend how the M8P is configured for this.
M8P initial product data says no support for Galileo, but maybe that
could change?
On 02/03/2016 23:22, RickHwang wrote:
> There is a $50 board with integrated RTK solution, larger size than ublox M8P
> though.
> https://twitter.com/NavSpark/status/705032188320813056
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/ublox-M8P-tp7573409p7573414.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
