[FOSS-GPS] ublox M8P
Jared Bench
jared.bench at gmail.com
Thu Mar 3 11:11:19 PST 2016
Ublox just announced a firmware update for the M8N that includes support
for Galileo. It's likely this will extend to the M8P.
On Thu, Mar 3, 2016 at 10:19 AM, anthony wooldridge <
arwooldridge at googlemail.com> wrote:
> Interesting device ( the NS-HP) , but GPS only I think.
> Satellite numbers often go below threshold, or optimum geometry, for RTK
> when using GPS only.
> Then you get a big jump reverting to single. So not good if you need 100%
> availability.
> Glonass doesn't help initial lockon AFAIK ( if integer ambiguity is
> switched off, at least in RTKlib) but might help hold an RTK solution once
> found.
> It would depend how the M8P is configured for this.
> M8P initial product data says no support for Galileo, but maybe that could
> change?
> On 02/03/2016 23:22, RickHwang wrote:
>> There is a $50 board with integrated RTK solution, larger size than ublox
>> M8P
>> though.
>> https://twitter.com/NavSpark/status/705032188320813056
>> View this message in context:
>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/ublox-M8P-tp7573409p7573414.html
>> Sent from the Open Source GPS-related discussion and support mailing list
>> archive at Nabble.com.
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160303/7c242451/attachment.html>
More information about the FOSS-GPS
