[FOSS-GPS] (no subject)
Michele Bavaro mic.bavaro at yahoo.co.uk
Mon May 23 01:33:28 PDT 2016
One good move would be to start using latest generation modules supported by uBlox, so that people don't have to suggest solutions based on hacks of previous models of ublox receivers.The 6M can be instructed to output RAW, just google a bit and you will find how, but better would be to actually focus on the "T" or "F" family.
    On Monday, 23 May 2016, 7:08, Bipin Adaki <bipin.adaki at gmail.com> wrote:
 I am currently working on a asset tracking project, in which i need submeter level accuracy. for the same i am using the Ublox7P(Rover over serial port for testing) and 6M (Base station over serial port). When I start RTKNAVI with settings shown in the link, RTK is not able to display the satellite SNR for the 6M module, for same settings I am able to see the SNR for 7P module and the module is working fine with U-center. I tried replacing the rover and base station still for 6M it does not show the SNR. But in streams it shows data is coming continuously.
https://docs.emlid.com/navio/RTKLIB/rtklib-rover-setup/
Please help me.
RegardsBipin Aadaki
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160523/70959c42/attachment.html>
More information about the FOSS-GPS mailing list
