[FOSS-GPS] Getting final RTK position from RTKNAVI to a GIS software
anthony wooldridge
arwooldridge at googlemail.com
Fri Sep 9 10:36:57 PDT 2016
You could try a virtual com port solution eg Com0com, or tcpip transfer
if the collection software acepts it.
Regards
Anthony
On 09/09/2016 17:55, Dhirendra Singh wrote:
> I use arcpad GPS data collection software which looks for a NMEA GPS
> device on a serial COM port in windows.
> I can take final RTK output as a NMEA text file from RTKNAVI output
> window. But*_ How can I get real time RTK position coordinates in the
> GIS software from RTKNAVI which is my ultimate objective of using
> RTKLIB ? _*One com port of the rover receiver is already used/engaged
> in RTKNAVI input. If we get final RTK NMEA output on a serial port
> that also gets engaged & can't be used in the GIS software. So what is
> the solution to the problem while using RTKLIB for real time RTK
> position coordinates ? I have used split serial port also to free a
> serial port. I have tried many options but failed to get real time
> final RTK output directly from RTKNAVI to the GIS software which I use
> in the field to get GPS position coordinates. Can anybody help with
> this issue ?
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160909/be747640/attachment.html>
More information about the FOSS-GPS
