[FOSS-GPS] RTKLib fixed baseline length
Anthony Wooldridge
arwooldridge at googlemail.com
Fri Jun 22 06:57:15 PDT 2018
Hi, RTKlib outputs the moving antenna position, not the polar vector from the base station, whether fixed base or moving.
However that vector is calculated somewhere in the software and is used in the graphical output of rtknavi. It would not take much programming change to output that vector, typically heading angle is the most useful from a moving base system. However the moving base solution is never as good as from a good fixed base, with sound physical reason, as there is less information to provide a solution.
A better way would be two fixed based solutions (2 rovers sharing one base) and manually extract the polar vector from the two solutions if that is what you need.
Regards Anthony
Sent from TypeApp
On 22 Jun 2018, 12:38 pm, at 12:38 pm, swanta2002 <swanta2002 at yahoo.com> wrote:
>Hi Marco & Kelly,
>I am new here, and I am presently working on the moving baseline
>concept
>with the RTKLIB software. I am aware that the solution should be a
>circle
>with a radius the length of the distance separating any two receivers.
>The
>result I got is far from being a circle, it is just the shape of my
>trajectory (rectangle), very low fix (1.8%), divergent lines and
>numerous
>spikes.
>I read where you guys said it works for you, did you get a circle as
>expected? and could you please intimate me on what to do to easily
>resolve
>this problem? I am really in a fix and need help concerning this.
>Sent from:
>http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/
>_______________________________________________
>This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>subscription
>For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20180622/f6de9e50/attachment.html>
More information about the FOSS-GPS
