[FOSS-GPS] [RTKlib RTKpost] Manually insert approximate coordinates form RINEX
kjerstiensrud kjersti.ensrud at outlook.com
Sat Apr 27 11:14:27 PDT 2019
I have been processing vectors and I had problems with the Base Station
coordinates. The solution I found a few months ago was to manually input the
approximate coordinates from the RINEX-file as X/Y/Z-ECEF and insert the
antenna height. And input the atx-file in files. Does anyone know if this is
an acceptable solution?
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/t395125/options_position.jpg>
Kind Regards
Kjersti
Sent from: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/
More information about the FOSS-GPS mailing list
