[FOSS-GPS] STR2STR
Márton Farkas
qwertz8888 at gmail.com
Tue Apr 23 02:20:02 PDT 2019
Dear colleagues,
I would like to use a Raspberry Pi to log raw GNSS data and to send NTRIP
correction to a u-blox receiver same time.
I'm using two str2str processes for this task. First provides the RTCM3
correction to the receiver, second logs the data stream from the receiver
to a ubx file. The baudrate is 460800, the navigation rate is 10 Hz,
RXM-RAWX and NAV-PVT messages are enabled only.
When I check the log file in u-center there are a lot of broken, unknown
messages.
I found at rtklibexplorer
<https://rtklibexplorer.wordpress.com/2018/08/14/comparison-of-the-u-blox-m8t-to-the-u-blox-m8p/>
there
is Output Received Stream to TCP Port option for the strsvr application.
How is it feasible on the Pi with str2str?
Thank you!
Best regards,
Marton
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190423/1f51930c/attachment.html>
More information about the FOSS-GPS
