[FOSS-GPS] Rtklib post process
adam cron
crontegy at gmail.com
Thu Mar 14 13:15:16 PDT 2019
Thank you for the response.
To be honest, I want corrected positions for my Phantom photo locations and
I am not sure the best way to go about it. So I’m not sure what I want with
regard to how to do it. I have read instructions online to get started but
I have a lot to learn and want to find the best way.
I will try dGNSS and some other things you mentioned. Thank you!
On Thu, Mar 14, 2019 at 11:46 AM atanu santra <bubunhhh at gmail.com> wrote:
> Dear Colleague,
> 1. a) If you want to do differential GNSS, please do the following :
> run the rtkpost > enter the .o and .n file of Base and only .o file of
> rover as input> select dgnss in processing option> execute.
> b) If the data of Base is of same day as rover and of 24 hrs then you will
> get the dgnss solution, no issue will be arisen.
> c) yes you can use final ephemeris of constellations but the observation
> files should be of same day.
> 2. If you want to do ppp for single receiver then you need final
> ehemerides, clk file, erp, antx file etc.
> Best regards
> On Wed, 13 Mar 2019 6:53 pm <foss-gps-request at lists.osgeo.org wrote:
>> Send FOSS-GPS mailing list submissions to
>> foss-gps at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.osgeo.org/mailman/listinfo/foss-gps
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> foss-gps-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of FOSS-GPS digest..."
>> Today's Topics:
>> 1. RTK_LIB_postprocessing (Иван Рыкин)
>> Message: 1
>> Date: Wed, 13 Mar 2019 15:55:53 +0300
>> From: Иван Рыкин <vanya-t-mac at mail.ru>
>> To: foss-gps at lists.osgeo.org
>> Subject: [FOSS-GPS] RTK_LIB_postprocessing
>> Message-ID: <1552481753.530901690 at f495.i.mail.ru>
>> Content-Type: text/plain; charset="utf-8"
>> Hi,
>> I am a student of SPBU. I am learning RTKlib
>> how to equalize (postprocess) gnss base (2 hours observation) using
>> reference station (24 hours observation). Rinex data available GPS
>> and GLONASS.
>> There are some questions:
>> 1. What kind of data I need use for reference station, only
>> navigation (.g and .n) and observation (.o or .d) ?
>> 2 - What kind of data I need use for gnss base, only
>> navigation (.g and .n) or observation (.o or .d) files too
>> 3. What kind of data I need use for reference station
>> and gnss base, only observation (.o or .d) files and as a navigation files
>> only final ephemerides
>> 4 - if we use final ephemerides we must use ppp-static or static?
>> 5 - why is the difference between output data if we use , is it normal ?
>> 6 - if my base is 10Hz, it means that every data must be 10Hz
>> for getting the precise XYZ? Data from the Reference station and for
>> example UAV must be the same 10Hz?
>> thank you for answering these questions.
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment.html
>> A non-text attachment was scrubbed...
>> Type: image/png
>> Desc: not available
>> URL: <
>> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment.png
>> Type: image/png
>> Desc: not available
>> URL: <
>> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0001.png
>> Type: image/png
>> Desc: not available
>> URL: <
>> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0002.png
>> Type: image/png
>> Desc: not available
>> URL: <
>> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0003.png
>> Type: image/png
>> Desc: not available
>> URL: <
>> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0004.png
>> Subject: Digest Footer
>> FOSS-GPS at lists.osgeo.org
>> End of FOSS-GPS Digest, Vol 111, Issue 1
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190314/5efe83ba/attachment-0001.html>
More information about the FOSS-GPS
