[FOSS-GPS] RTKlib help pls
drwho drwho at infidigm.net
Mon Nov 18 18:34:23 PST 2019
synaptic on Debain 10 says rtklib = v2.4.3+dfsg1-1.
I cloned 2.4.3b33 from github and type make in the RTKLIB/app/rtkrcv/gcc
dir.  After chmoding the two .sh files, rtkrcv runs and gets a solution
for single mode only.  kinematic is always no double-differenced
residual. I'll try rtknavi in windows.
On 2019-11-18 9:02 p.m., John Ackermann N8UR wrote:
> rtklib on Linux has a horribly broken configuration setup.  I fixed it
> several months ago and build Debian packages based on 2.4.3b31.  They
> might be in unstable by now (I'm not an official maintainer so had to go
> through intermediaries and I'm not sure what finally happened).  If they
> are not in the repos, I can point you to them on my web site.  I suppose
> it wouldn't be hard to build the programs outside of Debian and install
> them manually if you use some other distro.
> John
> jra at febo dot com
> On 11/18/19 6:16 PM, Bud Asterisk wrote:
>> Hi folks,
>> I have been playing with the RTKlib packages for a few months now.
>> Current setup is 2 CSG M8T receivers. Each connected to a Raspberry Pi
>> Zero W. The pi run str2str that I compiled on the pi. These connect to
>> RTKNAVI on my laptop without issue, all over wifi. Have 2 cell phones
>> ready to handle the data connection so I can take it out into the wild!
>> No problems at this point.
>> I want to use RTKRCV which I have compiled on a linux machine. Am able
>> to make config changes but the tool is telling me to restart after I
>> make a config change. Here is what I am doing:
>> rtkrcv> help rtkrcv ver.2.4.2start : start rtk serverstop : stop rtk
>> serverrestart : restart rtk seversolution [cycle] : show solutionstatus
>> [cycle] : show rtk statussatellite [-n] [cycle]: show satellite
>> statusobserv [-n] [cycle] : show observation datanavidata [cycle] : show
>> navigation datastream [cycle] : show stream statuserror : show
>> error/warning messagesoption [opt] : show option(s)set opt [val] : set
>> optionload [file] : load options from filesave [file] : save options to
>> filelog [file|off] : start/stop log to filehelp|? [path] : print
>> helpexit : exit and logout consoleshutdown : shutdown rtk server!command
>> [arg...]: execute command in shellrtkrcv> restart sh: 1: ./rtkstart.sh:
>> not foundcommand exec error: ./rtkstart.sh (32512)rtk server start
>> errorrtkrcv> start sh: 1: ./rtkstart.sh: not foundcommand exec error:
>> ./rtkstart.sh (32512)rtk server start errorrtkrcv> stop rtk server
>> stoprtkrcv> start sh: 1: ./rtkstart.sh: not foundcommand exec error:
>> It cant seem to find the start or restart commands....any wisdom? I only
>> did the compile of rtkrcv and no others.
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191118/8f3e35ee/attachment-0001.html>
More information about the FOSS-GPS mailing list
